It is currently Tue Jul 22, 2025 6:27 am
PostPosted: Tue Jun 19, 2007 10:33 am
Anyone know of a tutorial on the web, or even just a few pics of jigs for putting the slots in a slotted headstock?
I've seen a couple of pics at the LMII site (I think it was there anyway). There's gotta be a couple of ways to skin this cat without laying down a bunch of cash for a pre-made jig.
How do you guys do it?
PostPosted: Tue Jun 19, 2007 11:23 am
Hi Paul,
A couple of months ago I did a tutorial on slotted headstock jigs-it's in the archive.
Brad
PostPosted: Tue Jun 19, 2007 11:37 am
Last Name: Abercrombie
Hi, Paul-
BTW, you can attach the slotting jig to the headstock with a couple of SHORT screws in the area that will be cut away for the 'ramps'. With the side pieces locking to the taper, it's very secure.
Similarly, a simple jig for cutting the side tapers can be affixed by screws in the area that will be cut away for the slots.
I sometimes have problems with clamps vibrating loose when I'm using the router, and find screws more secure.
PostPosted: Tue Jun 19, 2007 1:58 pm
[QUOTE=ToddStock] If you are using individuasl tuners, drilling the holes with press is fine. If you are using three-on-a-plate tuners, a jig with very precise spacing is a good idea.
Thanks Tod, I hadn't thought of the accuracy required for three on a plate tuners. In fact I'm building two 12 fret 000's and I was going to do one with individual tuners and the other with three on a plate. I'll have to factor that in when I make my jig. BTW you'll be happy to know the books been sent on.
Brad, that was exactly what I was looking for. I knew I'd seen a tutorial somewhere not too long ago. Yours was the one I've been trying to find, Thanks.
PostPosted: Tue Jun 19, 2007 2:12 pm
I have the jig from the luthier tool company, and I have to say this thing is great. It is pretty much idiot proof if you take the time to set it up carefully.
I know this isn't the question you asked, but if you are considering buying a tool... I highly recommend it.
PostPosted: Wed Jun 20, 2007 7:05 am
Yes, the Luthier Tool jig is great. My only word of caution (and it's not the jig's fault) is that in the past I've bought 3 on a plate tuners with slightly irregularly spaced holes, so don't just assume the jig will put them in the right place.
Pete
